Export .DYN files as C# scripts
Hello everyone,
I am wanting to know if it is possible to export or convert a functioning Dynamo node into a C# script that I can add as a button to the Revit toolbar. I am wanting to be able to run these scripts independent of Dynamo.
Thanks,
Do you use Dynamo Player? Not exactly what you’re asking for, but is the same approach.
Christian,
conversion may or may not be possible, depending on what the script is doing. It requires quite a lot of specialist expertise in both the API and C#.
