API, Buttons and Dynamo
Dear all,
I am trying to find good reference to create button by API then link it with dynamo Script, as dynamo player working but instead of the player to have buttons and if so would be great to share the knowledge with us.
Thank you
for that you need Revit SDK Package first,
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2484975
then you have to access Dynamo library through API, i dont know if this possible.
let us see if anybody has an idea.
Hi @Mohammad_Nawar
You should give Dyno a look. It allows to add buttons to the revit ribbon pretty easilly
Hi @Mostafa_El_Ayoubi
I tried Dyno and it’s great, but it’s not free anymore and i wanted to understand how to link the add-ins with the dynamo i am familiar of making button but couldn’t figure out how to connect it with dynamo script
Really, nobody can help with that .!!
try XMAL UI. Here is a video I made on how that is done.
You can also use Python
Best of luck.
Thank you for the replay finally good reference. appreciated.
@Konrad_K_Sobon @Dimitar_Venkov @Kulkul @Thomas_Mahon @erfajo . i hope also if you can help with that or give us good references or a knowledge to start.
