dynamo problem
Hello,(note i’m french, thanks google)
Someone will have a solution I have a Malfunction on dynamo. I have 2 PCs with the same configuration, same version of dynamo and package.
(exe: package spring.mode)
PC1: creation and complete operation of the “toto” .dyn
(example: Springs.HostedInstance.ByPoints node = I have 12 outputs with usable value)
PC2: use of the “toto” .dyn BUG along the way
(example: Springs.HostedInstance.ByPoints node = I have 12 outputs with NULL value)
Ditto with other .dyn file and other packages (exe archi.lab)
On PC2 use or creation of dynamo file does not give any normal results, I have the impression
that python code does not work or no longer.
note: PC2 is my workstation grrr
LievX
January 21, 2020, 1:52pm
2
Hi @sbosarl , how are you? ca va? s’il vout plait, poste en francais, la traduction n’est pas bonne, mon francais c’est pas bon nonplus… sorry, mais je pense que sera plus comprensible de lire en francais… aussi, si tu peut poste une image de la routine… merci
Daan
January 21, 2020, 2:57pm
3
Please also upload a Dynamo File.
Did someone have an hint to find the origin of my problem ? I’m really stuck with this issue and can’t find a solution
For Information i try the following :
Run as administrator
Without Firewall
Without Protection solution
Reinstall of Run Python
Reinstall an other Dynamo version
Vérification of my configuration between 2 computer
Thank you for your time !
