Dynamo / Polysurface / Paneling continuity
Hi guys,
I’m facing an issue of paneling continuity in Dynamo.
I’ve modeled a complexe surface using freeform modeling in Fusion 360 witch result in a polysurface.
Now when I use Lunchbox in Dynamo to produce panels I cannot succed having uv continuity between my different surfaces. Some of them are working together but other do not blend the way I expect since they seems to have different UVs.
I’m little bit of a noob in Dynamo that’s why I think this issue is quite simple but I couldn’t find my answer on the internet.
Sorry, I cannot share an image since I’m not in the office until monday.
Thank you for your help guys.
Erwan
There are some good examples of paneling multiple surfaces using the pattern toolkit. I don’t recommend using lunchbox as it isn’t supported and hasn’t been for almost 7 years now.
Thank you very luch Jacob!
I 've made a research on this plugin and I only found some stuff on Dynamo for Alias.
No hits on Dynamo for Revit. Is this plugin running on Dynamo for Revit too?
Can you share some link of what you are talking about?
Thanks!
Same content works in any Dynamo type as this is built for Dynamo Core (sandbox), not particular to alias. You may have to provide some differing inputs is all, but it certainly will work.
Thank you Jacob, i’ll give it a try!
