Dynamo player wont stop running
Hello
I have a script that works just fine, but when I run the graph in dynamo player it wont stop running. I have to close dynamo player and restart it to be able to run the script again. Anyone have any idea what could be wrong?
@dana.defilippi is this the same issue you had a while back?
I do not recall this issue. I would recommend disabling any add-ins to see if the problem persists. :slight_smile:
Disable all Revit add-ins, remove any custom Dynamo packages, restart the cpu, and try running that. If it still occurs then grab your Dynamo log and Revit journal.
Thanks Jacob an Dana!
It was an add-in that messed it up.
Please share with the community which add-in caused this issue so they would solve similar problem they would encounter.
There is no definitive list. Disable the all, re-enable in groups, and check your journals for API_Error flags when the issue returns.
