Dynamo player not showing up in 2018.3
Hi All,
I am experiencing the exact same issue described below.
Does anyone has a solution which is not a clean install?
“I click on the Dynamo Player button it becomes grey but the player doesn’t pop up. When I close the Dynamo Player from within the Task manager by right clicking and selecting End Task the Dynamo Player button within Revit returns to before it was clicked.”
Only time I have seen this was when the window was shifted offscreen. Have you tried using Alt + Tab to see if you can find the window?
The window is not there.
Hello everyone,
I have the same problem, any help will be appreciated.
