Hi. thanks for your response. But this error opens on all models, even an empty model, immediately after clicking on Dynamo Player, and no specific script was executed.
Hi @alirahbar_2000 , we need some help with more info.
Can you go to task manager and look at GenerativeDesign.exe ?
There should like 4 processes there and one has a longer Command Line than the others ( you need to have Command Line option column checked ).
Can you give us the Command Line param string from there ?
Other thing that comes into mind : can go to “C:\Program Files\Autodesk\AECGenerativeDesign 2023\GenerativeDesignClient\resources\app” and delete all the adp* files from there ? (make sure to make a backup).
Thank you
Hello . Before clicking on Dynamo Player, there is no item called generative design, and after opening the dynamo player, it will open like the attached image.
Hi @alirahbar_2000 , than you for providing the info.
Can you provide another print screen of task manager with Command Line option checked (like in my post) ?
