Dynamo Player - File Content Change
I have built a script that works great in the full Dynamo program, but when I try to use it in the Dynamo Player it switches between Ready to Run and File Content Change every second or so, and then it will also reset the Input changes you try to make each time it switches from File Content Change at the bottom. Am I doing something wrong here?
I found this forum and this appears to be problem for me, too. I was trying to store my scripts on a shared network drive, and while now one was trying to access these scripts at the same time as me, being on the shared drive was causing the problem.
