CSV.WriteToFile is crashing Revit when run from Dynamo Player.
Scripts run fine when the node is removed from the graph.
Do you get any error msgs/tracebacks you can post?
If not, it would be helpful if you ca post a small portion of the file with only the relevant nodes so others can try reproduce it.
Details of error
Removed Mandrill to clear the warning, re-saved the custom node and script with new names, crashing without any tracebacks persists.
Would be interested in knowing if this problem is reproducible.
Mandrill wasn’t causing the issue here. Do you have more than one version of Dynamo installed on that machine? That might explain the load errors.
Installed:
Dynamo 0.7.6
Dynamo 0.8.2
Dynamo 0.9.1
Dynamo 1.2.1
Reinstalled mandrill and load warnings are gone.
Tried creating a custom node from scratch, still crashing Revit.
Thanks Konrad,
Is it really a problem to have older versions installed?
I’ve removed 1.0 and 1.1 thinking that would be enough.
