I’m using a Dynamo script I’ve downloaded for paramteric curtain panel.
This script gives you the ability to randomly change the extrusion of each Curtain Wall Panel to achieve a parametric façade in Revit, using Dynamo script to automate the changes. Each time you run the script you will get a different result. The cubicles will change its depth using a minimum and maximum depth values.
How can I get the data of the Extrusion parmater which is different to each item? Either by schedule or Excel.
For example: what is the average H of all panels used, how many H=500 are generated etc.
