Hi all, I’m relatively new on dynamo. I’m trying to produce a facade with different deep for all the extrusions. The first thing that i have done it’s to randomise the deep of the boxes families using the string deep parameter, what do you think? should be better to randomise the family types? Thanks!
I’d probably stick with your approach of controlling the depth parameter of the curtain panel, but I would generate the random depths a little differently
Thanks!
i need to keep a step of 500mm. I’ll try this, thanks!
great! thanks Vikram!
Mauro,
If you use that logic, you’ll get panels with same heights at a given time.
Ok Renè for the List Cycle? thanks
You’re repeating values. You need a different value for each panel.
