Dynamo notes disappair, python script doesn`t wor, why?
I have this issue that my dynamo is not working, since i put 2.0.3. I have problems.
I use dynamo 1.3.2. and 2.0.3. Python Script does not work! when i save a script and reopen it, some of the notes are desapair! Like categories, All elements of category, string from object,…
How can I fix that? i tried also de/reinstall without result? Shout I delete via “regedit” all related to dynamo…
…this topic is realy annoing regarding dynamo - it seems to be unstable from time to time…
I am glad about any help
KR
Andreas
Which version of Revit are you using?
were you on a 2.x version previously or only 1.3.2?
have you seen this page?
https://dynamobim.org/working-with-dynamo-in-revit-2016-and-revit-2019-simultaneously/
if you open the details for the notifications what dlls do they implicate?
2019-07-22_12h08_32%20Kopie
I localized the error. it is dynamo 2.0.3. it isn`t running stabil!
My current problem is Dynamo 2.0.2. is not runing just 1.3.2. :confused:
I don`t know - is it a failed installation a filepath problem?
KR
Andreas
I would clear your dynamo core folder and reinstall it.
It may be a bad installation - can you take an image of your Dynamo core 2 folder? Specifically looking for folders with the name libG_ ?
I got it but whats next?
Should I put there something? Dynamo Studio runs, anything else not!
Dynamo just runs on 2016 (1.3.2) but not on Revit 2017 and 2018 (all versions are updated)
2019-07-23_11h17_042019-07-23_11h19_18
2019-07-23_11h29_45
I reinstalled Revit 2018 including there updates, that was it!
