it would be good at least to know if it is working for you, so maybe the problem is my pc and not the dynamo
I don’t have the excel file, but I can confirm that opening the dyn and pathing it to a new excel file works. I should clarify, by "saving the file to a new location: I was referring to the excel document - move it to your C drive as that will ensure we know it’s not network associated.
Ok, It’s getting more extrange.
I tried to reinstall dynamo today and it is not working. But now, I’ve discovered that the new nodes that I am placing are working, but the old ones are not. The problem is that if I save the file and open it again they are not working.
So I understand that the nodes, file path, … is working correctly, but there is some problem in my computer.
I was having problems with another node today, also producing nulls.
It turns out it was one of the Add Ins that was messing with it.
Use this free app to quickly disable add ins, if you are keen on giving it a try.
I am facing the same issue.
after running dynamo file no error showing. But, it is not performing the operation. REFER SNAP. Thanks in advance
In your case everything’s is working until the last node - Can you tell us:
- what package is that from.
- which version of that package.
- which Revit year and build.
- and which Dynamo version.
