Dynamo not reading IFC correctly
Hi guys,
When I import a IFC file into revit this is what it looks like:
but when I then get the geometry of all the linked elements using the “Get all elements from linked model” node then the “element geometry” node I get this:
The openings aren’t generated correctly in dynamo. Does anyone have experience with this and a solution ?
After generating the geometry in dynamo I use the springnode node Instance.byGeometry and of course it then creates family-instances without the holes.
Help please,
Verdi
Hello there!
I have the same problem
I’m waiting to someone answer
