Dynamo not creating sheets from excel file
Trying to create 53 sheets. only 20 are being created. I have other screen shots that I can share.
I figured it out. I had to change it to Long Lacing. I have no idea what the means. So if somebody can explain what it does to me that would be super helpful.
If you’re hung up on lacing, then I suggest you give the Dynamo Primer another run through (or a first run through if you haven’t already done so). This section discusses lacing pretty well.
http://primer.dynamobim.org/en/06_Designing-with-Lists/6-1_whats-a-list.html
