Hello there. i have made a dynamo nodes to adjust my parameters. I have figured out with my Lenght parameter which is “Extrusion Start to Extrusion End”, now the next thing i need to do it with my “Mywidth” Parameter, which is dimension, and it doesn’t pop up in the family parameter list in Dynamo. How can i add it there to do same manipulations with that exact parameter? What shoud i do? Thank you in advance!
That is a type parameter, so you would have to get the family type from the family instance, and review the parameters which it has. The resulting value can be set there, but know that all the instances will receive the same value as you can’t vary type parameters.
let me try, thank you sir
I’m an alien… I have no gender… Can’t you see from my photo?
how do i do that?
i suggest that Extrusion is my only Parameter here, and “Mywidth” is my dimension, how do i make manipulations with dimension “Mywidth” in Dynamo? or how do i turn a dimension to a parameter?
What’s the correct polite gender neutral honorific on your planet?
https://nonbinary.wiki/wiki/Gender_neutral_titles
Well, as an alien it’s pretty hard to translate into human…
So best to avoid any gender language I reckon ![]()
pardon me dear alien
Are you trying to set the parameter value from within the family document as you’re showing here? Or from within a revit project?
The context will dramatically differ the required solution
Whoops sorry was on mobile and I thought you were in a family, I can now see it’s a project so use the methods above ![]()
i get the same warning
That’s because you’ve now added an extra node by the look of your screen grab below.
i updated the screens, check them again please dear Alien
wait, am i not in the family?
You tell me ![]()
