Dynamo Installation Issue
Translated by moderator. See below the line for original post
Hello
I have a problem with the installation of the dynamo, I can not use the nodes and scripts here ci_joint the message I received when I try to use the software, thank you for guiding me to the solution.
Cdt.
Original post below
Bonjour,
j’ai un problème au niveau de l’installation du dynamo, j’arrive pas à utiliser les noeuds et les scripts voilà ci_joint le message que j’ai reçu quand j’essye d’utiliser le logiciel, merci de me guider vers la solution.
Cdt.
@tabitmarouane ,
Which revit version do you use ? and Dynamo ones ?
2022-08-29_08h44_39
2022-08-29_08h44_51
KR
Andreas
I use just Dynamo sandbox without using Revit, so i guess this is why i can’t use these packages.
Kind Regards,
@tabitmarouane ,
i use sandbox too… but could be the version is not stable one… look at recommended cores, and install them
Hi guys, I try to use dynamo for RAS but unfortunately I received this message for each package I want to use it.
Thanks for your reactions !!
