Hi fellas!
Quick question: How do I get Dynamo for Revit 2016? Need it for an older project but I can’t seem to get it working. Latest Dynamo involves 2017 - 2019. Dynamo 1.2 installs and should be including Dynamo for Revit 2016 but it never shows in Revit.
Dynamo 1.3.3 and dynamo 2.0 does not support revit 2016, therefore uninstall 1.3.3(core and revit) and install dynamo 1.3.2 from http://dynamobuilds.com/.
Then if you still need dynamo for revit 2019, get the latest version which is dynamo 2.0 from same website indicated above.
Neat, worked like a charm. Thanks!
Be aware that Dynamo 2.0 is not backward compatible, so anything you create in that version cannot be opened in Dynamo 1.3.2 (in Revit 2016 or other Revit versions).
