Dynamo Error 101
After using a script dynamo simply is showing this without any nodes whenever i am reopening any scripts. I have tried restarting my machine the problem remains the same.
@User01 ,
puh
if
a.) restart dynamo
else
b.) restart Revit
else
c.) restart Your Computer
… or you grapht is too old! for any solution
KR
Andreas
Tried not working
My graphics is fine i was using it till now
@User01
which version of dynamo and revit do you have ? how old is the script?
Hi I guess its a conflict with a package or addin, try to disable your addins and remove your package until you find the issue…
This is a sign of a DLL conflict, usually the result of a Revit add-in or package.
  1. Close Revit and restart your CPU.
  2. Disable all Revit add-ins
  3. Rename the DynamoSetttings.xml and packages directory found in %appdata%/dynamo/Dynamo Revit/2.xx/ where xx is the Dynamo build you’re currently using (ie: udpated Revit 2022 would be 2.16). This will prevent any customizations to your package paths and any pre-loaded packages to not load.
  4. Launch Revit, and start a blank project from no template (select none in the drop down), and set the units to imperial
  5. Launch Dynamo and open your graph.
If the issue persists check your Revit journal for add-ins which weren’t disabled (search for vendor; only Autodesk, adsk, or some variation thereof should be present). If nothing was missed post the .dyn, your dynamo log file, and your Revit journal.
If the issue doesn’t persist restart again, undo the renaming of the settings and package path (you’ll have to delete the new versions), and repeat steps 3 and 4. If the issue still doesn’t re-occur we can confirm it’s an add-in. If the issue does re-occur you can start checking your installed packages in small groups until you identify the issue.
If it’s narrowed down to an add-in, confirm you’re using the latest version of all add-ins. Then restart Revit and disable in small groups until the issue no longer persists.
Thanks. I will try this.
Yes and try Jacobs awesome explanation :wink: it should be pinned ;)…for disable i like to use diroots appmanager…DiRoots App Manager | Install/Update Apps & enable/disable Revit addins
@sovitek @jacob.small
Thanks for your explanations. I am confident that this will work.
