Dynamo Error 0.0.3 (Orchid)
I keep getting error 0.0.3 when trying to download Orchid package - There is no description what this error means. I used to work with Orchid for a while and it worked perfectly (I download Orchid from github+install package in Dynamo). I tried uninstalling/installing Orchid again but I Think It’s a Dynamo issue.
What could be the problem?
Only download and follow instructions:
GitHub - erfajo/OrchidForDynamo: This repository contains the content of the Orchid package for Dynamo
Did you close all revit processess before install?
Hi, thank you for your replay.
I closed Dynamo & Revit before installation
Try manually remove Orchid and DanEDU files from your path first, than install.
Do you know where I can find instructions how to manually remove? You mean locating and deleting the files? By the way, didnt find a file named “DanEDU”.
Small update - the problem was solved by updating Revit, uinstalling & reinstalling Orchid!
Thanks,
