Dynamo Crashes with Citrix
This is probably a little specific, but I was wondering if anyone has seen anything similar to my situation.
When running Revit/Dynamo on Citrix, Dynamo will usually open properly on the first try. Once I try to reference a new custom node directory and open a graph (or start a new one) Dynamo locks up a freezes. After ending the task, new sessions of Dynamo will crash with the following errors immediately upon open:
In some situations Dynamo even crashes the first time, with the same errors, even before any new directories are added.
Has anyone seen anything like this or have any idea what could be causing Dynamo to crash? Any input is appreciated.
Hi Nick,
Which Dynamo version your using?
You can post your issue here https://github.com/DynamoDS/Dynamo/issues/ as well.
I’m using 1.0.0.1180.
I was having issues with 1.1 so I uninstalled it and went back to 1.0. I won’t be able to install 1.1 on Citrix for a few weeks.
I am researching better intra office collaboration tools for my office. Is the latest version of Dynamo and packages working on Xenapp?
Thanks, Simon
We haven’t had any issues since.
