I am having an issues with my Dynamo program. I have Revit 2024.3 and running Dynamo v.2.19.3. I wanted to start a new project and as soon as I add one node the whole program freezes. I can’t move the node around, delete it, or add anything else. Strangely enough, I can zoom in and out and search for different nodes on the side bar but again nothing else happens. I can’t even access the tabs on top. And, if I close out of the program and try to go back it it won’t load up. I have to completely close out of Revit and reopen everything but then it goes back to bugging out as soon as I start to work in it. Do I need to update revit? Do I need to redownload the dynamo source file? What is going on?
Hello @matthewl9GYTC,
Can you try to remove packages that you installed if there are any? Sometimes packages or plugins can create this type of issue due to different versions of the same library.
