Hello everyone…here is a simple problem i am running into where in m trying to render a veiw in revit with dynamo color gradient since revit doesn’t have ability to design gradient color material…hereby attaching the script…Thanks in advance for guidance.Dummy.dyn (60.4 KB)
Unfortunately, you kind of answered your own question. Revit doesn’t have the ability to do this. So you have to try something else. You would have to render the “object” in a way where you could apply solid colors to an array of objects to look like a gradient.
So that means Dynano Geometry Color Gradient cannot be exported to revit for render ?
If Revit can’t do it, Dynamo can’t make Revit do it. We are still limited by what Revit allows.
