hello,
Those are triangular stitches (it’s solid dynamo) it doesn’t deform like that. (for humor)
Cordially
christian.stan
hello,
Cordially
christian.stan
I thought Dynamo was designed to be as flexible as a rubber band ![]()
p = Point.ByCoordinates([0,0,w,w],[0,h,h-2,2]);
a = List.Flatten([p[0..3],p[0],p[1]],-1);
b = List.Flatten([p[1..3],p[0],p[2],p[3]],-1);
c = List.Flatten(arm (a,b,t).SubtractFrom(Solid.ByUnion(Circle.ByCenterPointRadius(p,t/5).ExtrudeAsSolid(Vector.ZAxis(),1))),-1);
d = GeometryColor.ByGeometryColor(c.Translate(Vector.ZAxis(),0..0.02..#6),Color.ByARGB([255,255,255,255,100,100],[163,113,52,98,61,108],[54,76,150,138,83,57],[47,119,163,92,99,55]));
def arm (st,en,tk)
v1 = Vector.ByTwoPoints(st,en);
a1 = v1.Normalized().AngleAboutAxis(Vector.XAxis(),Vector.ZAxis());
l1 = Line.ByStartPointDirectionLength(st,Vector.XAxis(),v1.Length).Translate(Vector.YAxis(),[tk/2,-tk/2]);
c1 = Arc.ByCenterPointRadiusAngle(st,tk/2,90,270,Vector.ZAxis());
c2 = PolyCurve.ByJoinedCurves([c1,l1[0],c1.Mirror(Plane.ByOriginNormal(st,Vector.XAxis())).Translate(Vector.XAxis(),v1.Length),l1[1]]).Patch();
return c2.Rotate(st,Vector.ZAxis(),-a1);
don`t forget to put autodesk in front of
p = Autodesk.Point.ByCoordinates([0,0,w,w],[0,h,h-2,2]);
c = List.Flatten(arm (a,b,t).SubtractFrom(Autodesk.Solid.ByUnion(Circle.ByCenterPointRadius(p,t/5).ExtrudeAsSolid(Autodesk.Vector.ZAxis(),1))),-1);
d = GeometryColor.ByGeometryColor(c.Translate(Autodesk.Vector.ZAxis(),0..0.02..#6),Color.ByARGB([255,255,255,255,100,100],[163,113,52,98,61,108],[54,76,150,138,83,57],[47,119,163,92,99,55]));
def arm (st,en,tk)
v1 = Autodesk.Vector.ByTwoPoints(st,en);
a1 = v1.Normalized().AngleAboutAxis(Autodesk.Vector.XAxis(),Vector.ZAxis());
l1 = Line.ByStartPointDirectionLength(st,Autodesk.Vector.XAxis(),v1.Length).Translate(Autodesk.Vector.YAxis(),[tk/2,-tk/2]);
c1 = Arc.ByCenterPointRadiusAngle(st,tk/2,90,270,Autodesk.Vector.ZAxis());
c2 = PolyCurve.ByJoinedCurves([c1,l1[0],c1.Mirror(Plane.ByOriginNormal(st,Autodesk.Vector.XAxis())).Translate(Autodesk.Vector.XAxis(),v1.Length),l1[1]]).Patch();
return c2.Rotate(st,Autodesk.Vector.ZAxis(),-a1);
i have still an error… warning
Here it works if I add ‘Geometry’ in front (Solid, Circle, Line, Arc).
i have still this 0 value in colors @Anton_Huizinga
Another great example, and valuable to learn from it ![]()
You mean there is no color? Add a ‘Watch 3D’ node to the last output port.
c = List.Flatten(arm (a,b,t).SubtractFrom(Autodesk.Geometry.Solid.ByUnion(Geometry.Circle.ByCenterPointRadius(p,t/5).ExtrudeAsSolid(Autodesk.Vector.ZAxis(),1))),-1);
def arm (st,en,tk)
l1 = Autodesk.Geometry.Line.ByStartPointDirectionLength(st,Autodesk.Vector.XAxis(),v1.Length).Translate(Autodesk.Vector.YAxis(),[tk/2,-tk/2]);
c1 = Autodesk.Geometry.Arc.ByCenterPointRadiusAngle(st,tk/2,90,270,Autodesk.Vector.ZAxis());
c2 = Autodesk.Geometry.PolyCurve.ByJoinedCurves([c1,l1[0],c1.Mirror(Plane.ByOriginNormal(st,Autodesk.Vector.XAxis())).Translate(Autodesk.Vector.XAxis(),v1.Length),l1[1]]).Patch();
Maybe you have other packages with the same node names.
I only had to add ‘Geometry’ in front of Solid, Circle, Line and Arc. No ‘Autodesk’, also not in front of a vector. What if you remove the ‘Autodesk’ part?
I am trying to create new logo for dynamo (just for fun)
Voting now open in the original post above!
OMG they’re amazing and made me laugh too!! ![]()
Can I vote for several?
The poll is set I’m afraid, but you can
do shout-outs in here on your favourites for discussion!
I’m just going to say it’s great to see the strange minds that inhabit this forum.
The very, very strange minds ![]()
@Alien ,
I have two favorites …
i think there should be categories like
best movie adaptation
best dead famous person resurrected as animal in dynamo
best MEP Art concept
My contribution
Always late. ![]()
script:
29 Juillet forum anglais recherche.dyn (46.6 KB)
Cordially
christian.stan
I kinda like how you’ve left the planes on. Gives it an ethereal quality ![]()
Yes a 3D “D” for dynamo, kudoos
