I am in the process of migrating many apps from 2022 to 2023. It is laborious. No graph has worked without changes. I have to check and test everything and often have to make minor edits to nodes. Sometimes If needs to be changed. archi lab.net needs to be the correct version: “2023.213.1523”.
I shall try the Bulk Graph Edits graphs. Remove the .txt from the end of the filename after downloading Bulk Graph Edits.zip.txt to extract.
