Dynamo 2.02 vs 2.03
Is Dynamo 2.03 stable? Im currently on 2.02 and wondering if its worth updating.
Also whats the difference between 2.03 and 2.3?
Yes, 2.0.3 has been stable since June, so you should be able to update without any issues. Dynamo 2.0.3 is the latest available version for Revit, whereas Dynamo 2.3.0 is for Dynamo Core (sandbox) and not available for Revit.
2.03 did help with some 2.02 stability issues, so if you are experiencing some upgrade. also note if your going to 2020 revit it ships with a newer version that will only run in 2020 and forward.
