Dynamo 2.0.3 in Revit 2020
Hi everyone!
I’m trying on install Dynamo 2.0.3 in Revit 2020 but apparently is not possible… I can’t understand, should be easy
Captura
Any solution??
Thanks in advice
Hi @nlardiesU5J7A,
Dynamo 2.3 is installed by default with Revit 2020.
It is not possible to install it manually.
Revit updates of the 3 latest versions of Revit automatically install newer versions of Dynamo.
Thank you @Alban_de_Chasteigner
But my question is if is possible to install older versions, as 2.0.3 in revit 2020
I have some scrips which run on older version but don’t on 2.3
It isn’t possible.
2.03 and 2.3 versions should be fully compatible.
The main difference could be that some packages haven’t been updated for a very long time and their custom nodes are showing errors in Dynamo 2.3.
In this case, it is better to use recently updated packages.
