i’m a new beginner user of dynamo starting learn it a few days ago, my probleme is the visual program doesn’t execute and dynamo stop up.
if someone can help me hope to resolve the probleme.
think you a lot
think you a lot
Do you mean there is no stop button to kill a script mid run? If so to my knowledge Dynamo does not have a kill function.
@Steven
thinks for your attention.
in dynamo nothing show up and it still block at " run started " for more than 10min without any result noj execution for the code
@Steven
yes i use dynamo for revit, for me the probleme is not in the programme but in execution i’ve restarted dynamo and trying other script it’s start working fine but after a while the same probleme repeted
What version of Revit are you using? Sounds like you need an update as certain versions had a conflict where keyboard input (ie: delete, ctrl +c, etc) would ‘stick’ to Revit keeping you from making headway.
i’m using revit 2019 exactly i’ve a conflict with some keybord input (delete, ctrl+c…)
Update to the latest version of 2019. This was fixed in 2019.1 and up.
my autodesk app show me that i have the latest version of revit because i’ve just install revit this evening and the bug still with dysfonction of some keybord input as you say
Also make sure you do not have a command in Revit active when you press Run. It will go and go until the command is stopped.
@jacob.small
this what i’ve as a version, if i install other version of revit as 2018 or 2017 it will work fine ?
Yes. Or you could update 2019 to the current version (2019.2.1). Autodesk Revit 2019 Product Updates
@jacob.small
think you very much @jacob.small for your help i very appreciate that think you the probleme solved for me i update revit and dynamo work fine for me know i can learn it hhh can you give some advice about learning dynamo
There are a few forum posts on this already, one of the more complete ones is here: Dynamo Class? - #3 by Kulkul
The Dynamo Primer is where I reccimend everyone start.
@jacob.small
think you very much for your help.
I really appreciate that and the way how community help each others of this forum think you a lot
