Hello fellow friends greetings, i’m new with dynamo software and i’m practicing my geometries and scripts, Actually i’m trying with some fews nodes to create cicular families in revit, the idea is get 3 different types of circles geometry from autocad process in dynamo and create that 3 family types in revit, i now i’m on a good way but could you give me some advice to complement please, thanks alot
Hola Amigo @Chriscalata buenas. Welcome to the forum. You need generate Points or get existings ones and feed the parameter node whit this information, extra tip, make attention with the dimention of the familys, the points, and the units that you use, they should be proportional; read this topic, also try to search similar topics I’m pretty sure there are other existing topics that can help you a lot!
