Hi
Im having a problem with the Dynamo sample file, that dumps property set values from solids to CSV. One of the property that is dumped is Handle, and since its in a format e.g 72E73, Excel automatically converts this to 7.20E+73. Its a problem because when i want to use UpdatePropertySets sample to update my properties from the csv, i get a script error:
Warning: TypeError : No method matches given arguments for OnExit: (<class ‘Autodesk.AutoCAD.ApplicationServices.DocumentLock’>, <class ‘type’>, <class ‘TypeError’>, <class ‘traceback’>) [’ File “”, line 26, in \n’, ’ File “C:\ProgramData\Autodesk\C3D 2022\Dynamo\samples\Data\AutoCAD\pset\pset_utils.py”, line 214, in update_ps_values_csv\n t.Commit()\n’]
I tried correcting this in Excel but since i have thousands of solids, this is not a viable solution to do by hand, find replace seems not to work in this case either. I was wondering if editing the Python script, that it creates a CSV that erases the scientific notation while the file is being created would do the trick, but i dont know how to do such a thing. Any help would be appreciated!
