Drawing lines from points
Hello everybody,
i just started to learning dynamo and i have made a simple script for drawing lines from points but i can not make them to draw in autocad i am getting this warning when i am using node Line.ByStartPointEndPoint, but when i use node Line.ByTwoPoints i am getting geometry in dynamo but not in autocad
“Warning: Line.ByTwoPoints expects argument type(s) (Point, Point, string, Block), but was called with (Autodesk.DesignScript.Geometry.Point, Autodesk.DesignScript.Geometry.Point, string, Function).”
Hi @starilav
Welcome to Dynamo Forum!
Could you please drop here screenshot of your graph?
Hi @starilav ,
Try the following guides below. Option 1 and 2.
Cheers,
Jowenn
that’s it, thanks for the help
