I have a list of “start points” and a list of “end points” each with 14 points that I am trying to have drawn into AutoCAD. The Line.ByStartPointEndPoint seems to be able to take these lists and draw each line in Dynamo, but when I use the AutoCAD Line.ByTwoPoints node to transfer these lines into AutoCAD, only the line for the index 0 points is drawn. Does anyone have a work around for this?
Thanks!!
AutoCAD lines|672x500
Hi, have you try to change the lacing mode is n the node?
Right click in the last node and change lacing mode.
Hi Javier! Thanks for the help. Unfortunately, that doesn’t solve my problem. The node output is a list of 14 lines, but only one of the lines (the first) is actually drawing in AutoCAD.
Hi @mbrayN4L27 did you tried ByGeometry (object.bygeometry) and (object.geometry) node?
Hi @i51vignesh! Thanks for the tip - I realized it had to do with the Point.Add node I was using. When I created a list from the Point.Add node rather than taking the points straight from that node to the Line.ByTwoPoints node it seemed to solve the problem.
Hello, can you show me the hole diagram?
