Hi all,
Just trying to do a red underline with black text. However, it won’t work in Revit. Is it possible to use dyanmo to select multiple text and draw a red detail line under each text?
Thanks in advance.
Hi all,
Thanks in advance.
Probably with a bounding box could be a way ![]()
Hello…strange have you tried restart
Yes, I have tried serval times.
May I know the version of Revit you are using.
I use 2022 In that case which version are you on
Very Strange which version are you In @viktor_kuzev
That was in 2021.
I just checked 2022 and it works normally there - no such issue
Allright Nice to know…havent test on 21
@sovitek I just checked 2020 - and there I get the exact same error message as OP.
Really weird, since there is no reason for that - the python node works in both 2020 and 2021 and it isn’t doing anything special.
Yes indeed really weird…hmmmm ![]()
Thanks @jw.vanasselt but still strange the ootb node doesnt work in 2021 for textnodes
@sovitek , I think that it wasn’t possible in the API till 2022 ![]()
It is very much possible, at least in 2021 and 2020 where I tested it with my python node
I have tried to run it in 2021. The element.boundingbox node is still not work. @viktor_kuzev’s script works for me. Thank you all of you.
