I was wondering if someone knows if it is possible to check door widths of fire escape routes using path of travel or some other means?
The other thing I hope to figure out, is how to create a schedule that contains the room occupancy and doors in the room.
Any help would be greatly appreciated!
@alex446m if you can get the geometry of the path, you can intersect it with a line created from doors location, these intersections (points) can be parameteratpoint, resulting distances from the start of the travel path.
You can get the occupancy from rooms and push/ set it as a parameter within your doors, a door schedule will suffice then, I guess.
Can you share your progress, maybe I look at it later?
