I set a file up a few weeks back to determine the size of some adaptive columns I made.
These are fully loaded into the revit model.
I used dynamo to determine where they are placed.
The columns generated successfully.
However I went back into the file today (with the originally revit file open, with all the families loaded)
I find that for each of the family nodes Dynamo has placed a random family and has not remembered what family I used to generate the original geometry.
I would have thought that once you choose a family using the family node that dynamo will look for this family even after you open the same file after close.
This is frustrating as I don’t want to keep telling dynamo which family to look for.
The other way would be to change the section sizes in revit manually once the raw geometry is placed.
This file has not been used for other revit models and is specifically for generating geometry for one file so I don’t understand why Dynamo has changed the family inputs?
