Hey guys,
So I have put the dynamo package Orchid on a server and multiple pc’s are connected. When I run the same script the Orchid nodes don’t work on all pc’s. On some I get the message/error code: A serious issue 0x00000007 has occurd please contact the author.
Sometimes the nodes just dont work and other times they do.
Does anyone have experience with this?
Kind regards,
Verdi
Generally speaking it isn’t recommended to load packages off a server, and instead move them to the users’ local package directory via robocopy, group policy, or other means. This is because both local and network security protocol are frequently updating, as is the OS, and concurrent file access isn’t truly permitted.
Once placed locally (and removing the reference to the network, do they all work? If not I recommend reaching out to the Orchid Package Github for support there.
Thanks for the tips. After your message I’ve installed the package locally and ran the script again. Then it worked. I’ve done this on 3 pc’s and it solved it on all 3. We will install the package on all the systems locally. Thanks for the tips!
