Do we have any nodes like Grid.ByStartPointEndPoint
I wanted to make a floor using CAD as a select element using dynamo.
do we have anything like Floor.ByStartPointEndPoint ? or some thing where we can make floor using CAD by dynamo?
grids
There are multiple floor creation nodes in the library; however a floor cannot be defined by two points - you need to provide a closed loop. What have you tried so far?
Hi Jacob! can you tell me which node will help me to make floor using CAD file in Dynamo?
There isn’t one node, but this will be of use: Dynamo Dictionary
Thanks for this. But i wanted to make the floor using CAD linked file. Any suggestion on that?
Use a method to select the cad lines, and form a polycurve.
What have you tried so far? How to get help on the Dynamo forums
Can you tell me how can i form a poly curve- which nodes will help me?
Search the Dynamo library for PolyCurve, go to that section of the library (the class name is a hyperlink), and look for constructors (green + in the library).
