I found a code to create Divided Surface for Mass with Python through this link:
Link
Here is the code and the result:
clr.AddReference('RevitAPI')
app = __revit__.Application
doc = __revit__.ActiveUIDocument.Document
t = Transaction(doc, 'Divide Surface.')
t.Start()
#Create a FilteredElementCollector
collector = FilteredElementCollector(doc)
collector.OfCategory(BuiltInCategory.OST_MassForm)
famtypeitr = collector.GetElementIdIterator()
famtypeitr.Reset()
for item in famtypeitr:
typeID = item
srfObj = doc.get_Element(typeID)
#Get Geometry Elements
geOptions = app.Create.NewGeometryOptions()
geOptions.ComputeReferences = True
geoElem = srfObj.get_Geometry(geOptions)
#For each geometry object in geometry elements
for geObj in geoElem.Objects:
#For each face on the geometry object
for face in geObj.Faces:
#Divide the face
divSrf = doc.FamilyCreate.NewDividedSurface(face.Reference)
#Establish spacing rules
srfU = divSrf.USpacingRule
srfU.SetLayoutFixedNumber(20, SpacingRuleJustification.Center,0,0)
srfV = divSrf.VSpacingRule
srfV.SetLayoutFixedNumber(20, SpacingRuleJustification.Center,0,0)
t.Commit()
__window__.Close()
It works on Conceptual Mass environment. But, I want to implement it inside Revit project.
So, I want to automate the sequence of (1) Click Mass > (2) Edit in-place > (3) Click surface > (4) Click divided surface (in the project) > (5) Select pattern by utilizing dynamo/ and Python. Here are the illustration:
Any answers and suggestions would be appreciated. Thank you ![]()
