Create Roof by Face of a mass family
I am trying to create Revit system family of ROOFS by Revit faces using a mass family as reference.
With the code below essentially it runs Roof model by Face
but I have to select the geometry in screen anyway, I would like to automate the selection of faces of the mass family to create the roofs:
app = DocumentManager.Instance.CurrentUIApplication.Application
clr.AddReference("RevitAPI")
result = []
# find out version number of Revit
if int(app.VersionNumber) == 2021:
	pCmd = RevitCommandId.LookupPostableCommandId(PostableCommand.RoofByFace)
# runs if true is fed into the node
if IN[0] == True:
	uiapp.PostCommand(pCmd)
	result = 'Success'
else :
	result = 'set run it to true'
OUT = result
Good morning.
Dear Ruben.
I would like to know if I can solve the creation of Roofs by surface…
I have tried to use your code but it does not work. I do not know if I should do something more specific… ?? I am using Revit 2023
