Is it possible to get the distance from main alignment to the offset alignment at station xx?
@Redli1 how about this?
Thats close, thank you!
The stations are on the main alignment and the offset shall be pependicular from the main alignment to the offset alignment
OK no problem, just swap the alignment inputs.
but then the offset distance is measured pependicular to the offset alignment. In widenings the result won’t be correct
