Dimensioning multiple windows (problem with levels and lacing)
I am trying to dimension all the windows on a sheet, with the genius loci package I get the references of the windows and the sketchplanes from the referenceplanes. But at the end of the script i can`t get the dimensions in revit. I think it is a problem with levels and lacing.
Can somebody help me?
Hi @jochem.kolthof,
The cross product lacing on the FamilyInstance Reference ByType node is not necessary :
Simplify your list structure and you should be good :slight_smile:
hmm strange, when i remove the cross lacing:
maybe i have an older package (and I have dynamo 2.3). yours is also called differently.
anyway, I can achive this also by reordering the list, and that seems to work.
Thanks!
You should update the Genius Loci package.
There have been a lot of improvements and it would simplify your graphs.
