Dimension Circle Radius
Hi All
I am trying to create a radial dimension on a detail item in a view. I can’t seem to get the API method AngularDimension.Create to work. My Python code returns the error “references should be at least two, non parallel and rays of the arc passed” so I am most likely not inputting the circle references the correct way.
I tried following the tread at the link below.
Thanks for your help.
import System
import Autodesk.DesignScript.Geometry as DSGeo
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
app = uiapp.Application
sdkNumber = int(app.VersionNumber)
#INPUTS
circleCurve = UnwrapElement(IN[0])
dimType = UnwrapElement(IN[1])
point = UnwrapElement(IN[2])
#CODE
ref = Reference (circleCurve)
activeView = doc.ActiveView
arc = circleCurve.GeometryCurve
arcCenter = arc.Center
arcCenterRef = circleCurve.CenterPointReference
refs = [ref,arcCenterRef]
AngularDimension.Create(doc,activeView,arc,refs,dimType)
OUT =  arcCenterRef,refArray
the NewRadialDimension method is not available in a project document (API limitation)
Ahh!
I’ve been going around in circles all morning trying to figure it out.
Thanks for the response.
Surely it won’t be that difficult to expose this.
Thanks again.
@bayowindapo Did you found out any methods for that. I am searching through, could not find any. Thanks
Hi i know it isnt radial dimension, but probably something here could work in some cases
Thanks will look into that but was looking for Diameter Dimension. This is also helpful
can easy work for diameter, just connect curves endpoints instead of circle center
ok thanks
Hello. I never did, unfortunately.
ok @bayowindapo .
@jacob.small can you throw your light on this
Not exposed in the API means it cannot really be done.
The linear dimension shown here is the closest alternative and the root I would go.
