Create Dimension Programmatically
Hi community,
I have been working on creating linear dimension between some family instances while some problems baffles me a lot.
I have the sample Revit file and dynamo file with more detailed comments uploaded at the bottom, :point_down:
Latest problem: Invalid number of references.
What I am trying to do is creating a linear dimension between the left edges on two boxes (1st and 4th) in a section view.
Like this:
What I have accomplished is create the dimension by referencing two detail lines drawn on the boxes.
Using method: NewDimension(view, line, referenceArray)
I sketched a model line on the wall serving as the second argument for the method.
Code in Python node:
sel = uidoc.Selection
col = FilteredElementCollector(doc)
c_1 = UnwrapElement(IN[0]).GeometryCurve
c_2 = UnwrapElement(IN[1]).GeometryCurve
direction_curve = UnwrapElement(IN[2]).GeometryCurve
ref_array = ReferenceArray()
ref_array.Append(c_1.GetEndPointReference(0))
ref_array.Append(c_2.GetEndPointReference(0))
doc.Create.NewDimension(doc.ActiveView, direction_curve, ref_array)
OUT = 0
Creation succeed:
To:
But I really want to use the native references on the box instead of these detail lines.
So, I tried to retrieve the box geometry specific to the section view, and use one of the lines I have as reference.
elem = UnwrapElement(IN[0])
opt = Options()
opt.ComputeReferences = True
opt.IncludeNonVisibleObjects = True
opt.View = doc.ActiveView
lst = list(elem.get_Geometry(opt))
solid = lst[0]
geo_instance = lst[1]
instance_geo = list(geo_instance.GetInstanceGeometry())
OUT = solid.ToProtoType(), instance_geo[1:]
I separate the solid from the lines and convert it to ProtoGeometry just for previewing where the lines are on the box.
Now, left edges obtained.
Creation failed due to:
Line 53, the NewDimension() method, seems these two native references are not valid for creating dimension.
ref_array.Append(IN[0].Reference)
ref_array.Append(IN[1].Reference)
direction_line = UnwrapElement(IN[2]).GeometryCurve
dimension = doc.Create.NewDimension(doc.ActiveView, direction_line, ref_array)
OUT = dimension.ToDSType(True)
Really appreciate ur help!:slightly_smiling_face:
Family & Dynamo Script & Revit File
Hi, you need to get reference planes in your family
Use for example FamilyInstance.GetReferences(element, FamilyInstanceReferenceType.Left)
Here you can find all reference types https://www.revitapidocs.com/2018/ab424c61-4b80-9dcd-3f9a-7b35fa670edf.htm
Hi @jshial,
Maybe not the answer you’re waiting for, but it’s easier using a package.
Works like a charm! Thx!
Thx, helpful as always!
