Creat New radial/diameter dimension by Revit API - Python
Hi everyone,
I’m currently working with the python code for create the new radial/diameter dimension for arc base on the revit API but I did not understand the reason that cannot find the NewRadialDimension or NewDiameterDimension when I was adding “from Autodesk.Revit.Creation import *” as well.
Also my code is
doc =  DocumentManager.Instance.CurrentDBDocument
app = DocumentManager.Instance.CurrentUIApplication.Application
clr.AddReference("RevitAPI")
view = UnwrapElement(IN[0])
arc = UnwrapElement(IN[1])
point = UnwrapElement(IN[2])
dim = doc.Create.NewRadialDimension(view, arc, point)
OUT = dim
Do you know any reason and please help me on this stuff that will be much appreciated. Many thanks
Hello @quantranarc
you can’t use doc.Create.NewRadialDimension() inside a project document (only in a family document)
instead, try to use this method
https://www.revitapidocs.com/2020/2e3b9201-d5fa-3cdb-53e4-8e204bda1fe5.htm
