ArcLengthDimension
Hello everyone,
I’m trying the apply the NewArcLengthDimension method from the Revit 2017 API to a dynamo python node
To create dimensions for Arcs, but I’m still new to Dynamo and Python can someone help with that
http://www.revitapidocs.com/2017/a33279db-ba00-7cb7-1cea-9f4eac33b747.htm
im not found the solution but
im think its must looks like this:
clr.AddReference('RevitAPI')
from Revit.Elements import *
arc=UnwrapElement(IN[0]).GeometryCurve
arc_ref=arc.Reference
refs = ReferenceArray()
refs.Append(UnwrapElement(arc).GetEndPointReference(0))
refs.Append(UnwrapElement(arc).GetEndPointReference(1))
dimension =doc.FamilyCreate.NewArcLengthDimension(doc.ActiveView, arc, arc_ref, refs)
OUT =arc, arc_ref, refs, dimension
And may be anybody explain how correctly use FamilyItemFactory Class
because of for example we cant use :
dimension =doc.Create.NewArcLengthDimension(doc.ActiveView, arc, arc_ref, refs)
its - not a ItemFactoryBase Class
ref1=UnwrapElement(arc).GetEndPointReference(0)
ref2=UnwrapElement(arc).GetEndPointReference(1)
dimension = doc.FamilyCreate.NewArcLengthDimension(doc.ActiveView, arc, arc_ref, ref1, ref2)
OUT =arc, arc_ref, dimension
This seems to work for me in a family. But I think the method is not available in the project environment.
I get:
"Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed.
File “”, line 29, in
AttributeError: ‘Document’ object has no attribute ‘NewArcLengthDimension’ "
You are right @viktor_kuzev its work only inside of family! …
I am think what is so strange… I think it’s useless if only works inside family
May be exist another way (Using Revit API) to do this in revit Document ?
and may be:
we can do it in revit manually:
this means that we can do it in Revit API! Right?
I went through the Revit API but the method is only available within a family unfortunately
had the same issue when I tried doc, i though maybe something wrong with my code that’s why I asked for help
It should be but unfortunately I don’t know how, Will keep looking in the Revit API maybe there is something else
