DetailCurve.Bycurve warning
Due a change in Dynamo we currently have a warning on the output of a “DetailCurve.Bycurve” node (see fig. 1). We got this after a run of the script, while it ran smootly on december 20 (see post Cylinder from Dynamo to Revit ).
Fig. 1
Does anyone have a solution for this?
Thanks in advance.
@j.boonen It looks like on December 20 you were running it on Site Plan and now you are trying to run it on a 3D View.
As far as I know, Revit doesn’t allow drawing a Detail Line in a 3D view (unless you have Set a Work Plane) and hence Dynamo is throwing an error.
@AmolShah problem solved :blush:
Thanks!
Fig. 1
