Deploying a default folder location, doesn't work
You’re right, I was missing something. I thought this was no longer required, but it seems like you do still need to include these encrypted files for the path to actually update.
You can manually set Player to the correct location, close, then copy those files from your local player settings to a shared location. Your script would then have to copy those files to each user’s settings as well.
