Revit Template with Hyperlink Object to point dynamo to play folder
In order to change where Dynamo Player defaults to looking for scripts you only need to copy the two encrypted files located here: AppData\Local\dynamoplayer\User data\dynamoplayerinstance 1\Default\Local Storage
There’s another file (I think Preferences) that forces the directory to open to the same location, but that’s not necessary to get this process to work.
This is the graph I use:
