I’ve made a custom node which creates a Excel file using a dll made in Visual Studio. Once the file is created I end the transaction and start a new transaction using common Dynamo nodes. I feed in the new file in Dynamo Excel and create points and curves using Dynamo. It works correctly but when I delete the Excel file from the folder it crashes Revit. This happens even after closing Dynamo.
I’m unsure where to start and how to debug this. I can send over any information that would help figure out why this is happening.
c# code used to generate Excel file:
