Data.ExportExcel
Hello everyone,
Hello everyone,
Does anyone know why I have this warning now when I want to export to Excel?
The problem is the same for Revit 2021 and 2022, everything was working fine a while ago.
Thank so much
Assuming inputs are all valid it’s likely the ‘online repair’ issue. Searching that phrase on the forums will take you to the solution a few times over but effectively you need to take Windows/Excel through an online repair as the needed libraries aren’t present after windows updates for that node to run.
Please use the search function before creating a new topic on the same issue:
Otherwise our forum will consist of 25% “excel issue”-topics :sweat_smile:
thank you
